Normal Topic how to position node??????? (Read 2631 times)
duclm
Sep 2nd, 2011 at 2:57am
I am new to MindFusion.
I am trying to create a series of nodes and place them in with predefined locations. For some reason, it does not work.
Dim nodeMap As New Dictionary(Of String, DiagramNode)
Dim bounds As New Rect(600, 600, 100, 200)
Dim myShape As Shape
myShape = GetShape(r("NodeTypeDesc"))
Dim DiagramNode = diagram.Factory.CreateShapeNode(New Rect(New Size(bounds.Width, bounds.Height)), myShape)
DiagramNode.Bounds = New Rect(500, 500, 50, 200)
'Dim DiagramNode = New CustomNodeStart()
DiagramNode.Image = New BitmapImage(New Uri("ac0026-64.png", UriKind.Relative))
DiagramNode.ImageAlign = ImageAlign.TopCenter
DiagramNode.Text = r("FlowChartItemDesc").ToString
DiagramNode.Uid = r("FlowChartItemId").ToString
'objNode = New clsNode(r("FlowChartItemId"), r("NodeTypeDesc"), r("FlowChartItemDesc").ToString, New Rect(0, 0, 90, 50), myShape, r("FlowChartParentId"), r("FlowChartChildId"))
'm_objNodeCollection.Add(objNode)
nodeMap(r("FlowChartItemId").ToString) = DiagramNode
diagram.Nodes.Add(DiagramNode)
i am not sure if i am doing any wrongs?
Re: how to position node???????
Reply #1 - Sep 2nd, 2011 at 4:44am
What does not work exactly?
This line will move the node to position 500,500, which could be outside the visible part of the diagram depending on the diagram origin point and measure unit:
Also you shouldn't call diagram.Nodes.Add(DiagramNode) in this case, since CreateShapeNode automatically adds the node. Call Nodes.Add only after using the node class constructor to create nodes.
duclm
Reply #2 - Sep 2nd, 2011 at 5:53am
oh sorry i forgot to comment out that line
it should not be there.
Anyway, i didnot specify height and width for my diagram. I also tried to change value of DiagramNode.Bounds and the position of my node is still the same....
Reply #3 - Sep 2nd, 2011 at 6:03am
Does the node stay at the top-left of the diagram regardless of its Bounds value? In such case check if you aren't calling the ResizeToFitItems method later - it will set diagram.Bounds to the union of all nodes, and so the left-most nodes will appear close to the border. If you need to preserve the diagram origin, you could do something like this:
dim diagramBounds = diagram.GetContentBounds(...)
diagramBounds.X = 0
diagramBounds.Y = 0
diagram.Bounds = diagramBounds
duclm
Reply #4 - Sep 2nd, 2011 at 6:18am
Thank you, i will try that and let you know.
Good weekend...
