Normal Topic Draw Link from another Link (Read 2215 times)
SL_developer
coding rocks
Aug 23rd, 2011 at 12:08pm
Hi
Is it possible to draw a Link from another Link?
In my case,
Suppose Node1(Rectangle) is connected (via Link1) to Node2 (Decision). I want to draw a new Link2 from Link1 to Node3 (Rectangle).
So the Origin for Link2 will be Link1 & destination will be Node3.
Re: Draw Link from another Link
Reply #1 - Aug 23rd, 2011 at 12:26pm
It's not possible. You can insert a tiny node between the links, and possibly make it invisible, to achieve something similar. For an example, see the "Ternary connections" sample project that comes with our WPF control:
SL_developer
coding rocks
Reply #2 - Aug 23rd, 2011 at 1:30pm
Ok Thanks , I will try this & let you know if any problem.
