Normal Topic network diagram (Read 2370 times)
superNova
network diagram
Aug 25th, 2011 at 6:26am
Can i able to create network Diagram of management System.To create  a Network Diagram  through code , & so what data i need to create a network diagram. but for more detail i want to know can i create network diagram through coding features or via its only painting feature.
Re: network diagram
Reply #1 - Aug 25th, 2011 at 7:42am
You can create it by calling the diagram.getFactory().createShapeNode() method for each node in the system, and Factory.createDiagramLink() for each link. Then apply some of the automatic layout algorithms, e.g. try LayeredLayout or AnnealLayout.
