Normal Topic Selection behavior without Modify (Read 1881 times)
nsandhu
Aug 26th, 2011 at 4:59pm
Is there a Behavior mode that allows selection but not modification? or if not does someone have a sample on how to implement a CustomBehavior doing selection only for DiagramItem(s)?
Re: Selection behavior without Modify
Reply #1 - Aug 26th, 2011 at 5:11pm
You could use the Modify behavior and call args.cancel() from the nodeModifying and linkModifying event handlers.
