Normal Topic Paste DiagramNodes from clipboard (Read 2207 times)
Hunter
Sep 13th, 2011 at 9:13am
Hello.
I have the following question.
The method PasteFromClipboard hase the parameter offset as Vector. I saw the code of the library and concluded that this is the offset between source copied objects and objects which will be pasted. But how can I paste the Diagram Nodes  when I copy them from one diagram and need to paste into another diagram into the mouse cursor position?
Thanks.
Re: Paste DiagramNodes from clipboard
Reply #1 - Sep 13th, 2011 at 9:28am
Call the MoveSelection method from this topic after calling PasteFromClipboard:
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=122710007...
Hunter
Reply #2 - Sep 13th, 2011 at 11:02am
Thank you!
