Normal Topic Inplaceedit & Grid.HeadersHook (Read 4321 times)
Amosius
Sep 27th, 2011 at 10:19am
I would like when changing node.Text in Inplaceedit mode, that:
1) node.Text ist already selected so it is possible to overwrite complete Text (something like node.Text.SelectAll())
2) I would like to change text size of Inplaceedit according to text size of node.
3) I read in your documentation about Grid.HeadersHook but i can't find this property. I would like to freeze my headers, so that users always can see them. I tried diagram.LaneGrid.HeadersHook but this property does not exist.
Thx in advance,
Amosius
Re: Inplaceedit & Grid.HeadersHook
Reply #1 - Sep 27th, 2011 at 10:30am
1 and 2 you can do from the EnterInplaceEditMode event handler.
3) This is not available in the WPF version of the control yet.
Amosius
Reply #2 - Sep 27th, 2011 at 12:09pm
Thx, EnterInplaceEditMode was what i am looking for.
I spoke with several users and they would like to freeze headers like they do in MS Excel. So would it be possible to convert this control to WPF version?
Best regards,
Amosius
Reply #3 - Sep 28th, 2011 at 8:40am
We'll try to implement it for the next release.
Best regards,
Amosius
Reply #4 - Sep 28th, 2011 at 1:53pm
That would be very cool! Almost every user was asking this feature Smiley
Amosius
Reply #5 - Nov 2nd, 2011 at 1:02pm
Please check the LaneGrid.HookHeaders property in this build:
https://www.mindfusion.eu/_beta/wpfdiag_hookheaders.zip
Amosius
Reply #6 - Nov 10th, 2011 at 5:40pm
Hello Stoyan,
yes, it looks good.
I recognized one problem:
I had so far "HeadersOnTop = false". With this property i could do an inplace edit.
Now i switched to "HeadersOnTop = true" (it looks much better for the user) but my inplace edit possibility was gone...
Beside of this, it is good Smiley
Amosius
Reply #7 - Nov 22nd, 2011 at 4:06pm
Hi Amosius,
With HeadersOnTop enabled, the textbox was in a layer behind the one that renders headers, so edit kind of worked but you wouldn't see the new header labels being typed Smiley This version should fix that:
https://mindfusion.eu/_beta/wpfdiag_editontop.zip
