Normal Topic problem with serialize (Read 2545 times)
jackhuclan
Nov 17th, 2011 at 9:37am
I failed to serialize the DiagramNode when I use the tag property of the DiagramNode to bind a object which signed serializable and had an event ,I can serialize the object without event .so can you help me to find some way to serialize such object,or some way not to serialize the event?
[Serializable]
pubic class Sample()
     public string Name{get;set}
     public event EventHandler PropertyChanged;
DiagramNode node=new DiagramNode();
node.tag=new Sample();
thanks
Re: problem with serialize
Reply #1 - Nov 17th, 2011 at 9:40am
Do you mean there is an event handler attached to the tag object, and you need to attach it again after deserialization?
jackhuclan
Reply #2 - Nov 17th, 2011 at 12:10pm
Stoyo wrote on Nov 17th, 2011 at 9:40am:
I don't need to attach it again. Because I need to be notified when I modify the property of object referenced by the tag property.But once I added the event ,I can't serialize the DiagramNode itself.
thanks for you help.
Reply #3 - Nov 17th, 2011 at 12:15pm
Does the built-in serialization throw any exception if there's an event handler attached? Or does it throw even if there's only the event declaration in the class without handlers attached to it? In the latter case you will have to implement custom serialization by handling the SerializeTag and DeserializeTag events. Otherwise, you could temporarily detach the event handlers before serialization, and attach them again afterwards.
