Normal Topic Form Clicked (Read 1663 times)
PDM.
Senior Member
Form Clicked
Oct 5th, 2011 at 7:57pm
Inside form clicked i need filter some time if eventis left mouse click or right mouse click
Im tring this but not work:
 private void form_Clicked(object sender, DiagramEventArgs e)
     if (Mouse.LeftButton == MouseButtonState.Pressed)
    /// mouse left click action here
This not work:
	    if (e.MouseButton == MouseButton.Left)
Error      11      'MouseButton' is an ambiguous reference between 'System.Windows.Input.MouseButton' and 'MindFusion.Diagramming.Wpf.MouseButton'
Re: Form Clicked
Reply #1 - Oct 6th, 2011 at 7:59am
Remove the 'using System.Windows.Input;' statement if you don't need classes from this namespace, or otherwise specify the fully qualified type name:
if (e.MouseButton == MindFusion.Diagramming.Wpf.MouseButton.Left)
