Normal Topic Move node in DiagramNodeCollection? (Read 2317 times)
Amosius
Oct 13th, 2011 at 2:40pm
Hi, i would like to move a node inside my collection in Diagram.Nodes.
I tried to remove my node and insert it, but in a previous
topic you explained that insertion is not supported due to some event handlers...
Hmm... any hint how i could move one node without clearing and adding all nodes again?
Amosius
Re: Move node in DiagramNodeCollection?
Reply #1 - Oct 13th, 2011 at 3:03pm
Try shifting the nodes in the collection by assigning them to new positions - the assignment should not trigger the built-in handlers. Here is a sample (untested) method which should do that:
void MoveNode(int oldPos, int newPos)
	var node = d.Nodes[oldPos];
	int dir = newPos > oldPos ? 1 : -1;
	for (int i = oldPos; i != newPos; i += dir)
		d.Nodes[i] = d.Nodes[i + dir];
	d.Nodes[newPos] = node;
Amosius
Reply #2 - Oct 14th, 2011 at 11:08am
That does the trick Smiley
Thx. Amosius
