Normal Topic Animated gif in a box (Read 3752 times)
JR
Oct 7th, 2011 at 12:28pm
I am testing your activeX version.
I have developped (as customer) a JDiagram application with animated gif in shapenodes.
I am trying to do the same thing in powerbuilder with the following code.
[code]
oleobject noeud
// Creation of a box
noeud = ole_flowchart.object.createbox (10, 10, 200, 200)
noeud.text = "Task1"
noeud.loadpicture ("D:\workspace_eclipse\VegaWebGraphe\images\engrenage.gif")
[/code]
The image is displayed but is not animated.
Is it possible to display animated gif in the activeX version ?
Regards
Re: Animated gif in a box
Reply #1 - Oct 7th, 2011 at 2:11pm
Unfortunately you cannot show animated gifs in the ActiveX version since the OLE StdPicture type cannot load them. You could use a third party library to load the GIF frames and assign them to the node from a timer, e.g. check this one:
http://www.planet-source-code.com/vb/scripts/ShowCode.asp?lngWId=1&txtCodeId=822...
The Java control doesn't do anything to play animated GIFs either, but the Java's drawImage function takes care of that automatically.
JR
Reply #2 - Oct 7th, 2011 at 2:28pm
It' a pity.
I will look for use only not animated pictures
Thank you anyway.
