Normal Topic WRONG 'Default Item Template' :-( (Read 7185 times)
zyko
Nov 3rd, 2011 at 4:57pm
i'm trying to use your 'Default ItemTemplate'.
(adapt it)
http://www.mindfusion.eu/onlinehelp/wpfplanner/The_Default_Item_Template.htm
BUT: things are wrong in ResizeBands area.
neither
ItemSettings="{TemplateBinding ItemSettings}"
NOR
ResizeBandsVisible="{TemplateBinding Selected}"
works.
Both propertys are readonly so trying to set them FAILS of course.
seems to be 'old code'...
would be great to get 'CORRECT SAMPLE' Code for the default setting!
g
zyko
Re: WRONG 'Default Item Template' :-(
Reply #1 - Nov 4th, 2011 at 7:15am
These properties are not read-only. What is the error you are getting? Also, what version of the control do you use?
zyko
Reply #2 - Nov 4th, 2011 at 9:38am
Hi Meppy,
MindFusion.Scheduling for WPF
Q3 2010:
according to docu
http://www.mindfusion.eu/onlinehelp/wpfplanner/P_MindFusion_Scheduling_Wpf_Resiz...
at least NOW and in past ItemSettings seems to be readonly
public ItemSettings ItemSettings { get; }
in my version Q3 2010 ResizeBandsVisible is readonly too according to your delivered HTML help docu AND my code experiments.
public bool ResizeBandsVisible { get; }
although now things might have change in newer versions according to
BUT Orientation is used to set in the sample too as
Orientation="{TemplateBinding Orientation}"
in real it's 'god thanks' not read only
the following sample code
ResizeBands rb = new ResizeBands();
rb.Orientation = new MindFusion.Scheduling.Wpf.Orientation();
rb.ItemSettings = new ItemSettings();
rb.ResizeBandsVisible = false;
in q3 2010 leads to the following compiler errors
Property or indexer 'MindFusion.Scheduling.Wpf.ResizeBands.ItemSettings' cannot be assigned to -- it is read only
Property or indexer 'MindFusion.Scheduling.Wpf.ResizeBands.ResizeBandsVisible' cannot be assigned to -- it is read only
and of course things fail in xaml giving the same errors.
the setting Orientation goes ok - kindly ignoring doku restrictions *gg*
you have some 'different things' in code and doku
if you've a real working sample for q3 2010 for 'Default ItemTemplate' i'ld be happy...
Reply #3 - Nov 4th, 2011 at 10:09am
The setters of the properties in question were indeed internal back in version Q3.2010. This was a bug and the property setters were exposed in a later release. Please, check the clients area for an updated version of the controls.
I hope this helps.
zyko
Reply #4 - Nov 4th, 2011 at 10:13am
i've got no login for
http://www.clientsarea.eu/Default.aspx
i bought this component via componentsource.
i'm not needing any new features and i'm not willing to BUY an upgrade, becouse someone else made a bug.
i only want to have things running as they should.
can you give me an update for free or sample code that really works in my version - what did you use internally in q3???
Reply #5 - Nov 4th, 2011 at 10:38am
Click on the Registration link and enter the order number you received from ComponentSource. After you complete the registration our administrators will approve it and you will be able to download the most recent version of the package.
zyko
Reply #6 - Nov 4th, 2011 at 10:41am
registration done - waiting for approval...
zyko
Reply #7 - Nov 4th, 2011 at 1:20pm
Hi Meppy + MindFusion Support-Team,
THX THX THX
anything now works to my complete satisfaction in Q4 2011 Smiley
