Normal Topic custom diagram link lost headshape? (Read 4409 times)
darby
Nov 4th, 2011 at 6:06am
I have some custom classes.
- ScenarioLink : DiagramLink
- ScenarioNode : TemplatedNode
- ScenarioDiagram : Diagram
- ScenarioDiagramBehavior : DrawLinksBehavior
And, ScenarioLink have ArrowHeads.Triangle for HeadShape
this is defined of ScenarioLink class
public class ScenarioLink : DiagramLink
    public ScenarioLinkId LinkId { get; set; }
    public ScenarioLink(Diagram parent)
	  : base(parent)
	  InitLink();
    public ScenarioLink(Diagram parent, DiagramNode origin, DiagramNode dest)
	  : base(parent, origin, dest)
	  InitLink();
    private void InitLink()
    public override DiagramItem Clone(bool clipboard)
	  var link = new ScenarioLink(this.Parent, this.Origin, this.Destination)
		{ Text = this.Text, SegmentCount = 3, AutoRoute = true, HeadShape = ArrowHeads.Triangle };
	  return link;
    protected override void SaveToXml(System.Xml.XmlElement xmlElement, XmlPersistContext context)
	  base.SaveToXml(xmlElement, context);
	  context.WriteString(LinkId.Value, "LinkId", xmlElement);
    protected override void LoadFromXml(System.Xml.XmlElement xmlElement, XmlPersistContext context)
	  base.LoadFromXml(xmlElement, context);
	  LinkId = new ScenarioLinkId(new Guid(context.ReadString("LinkId", xmlElement)));
    protected override void OnAdd()
	  base.OnAdd();
	  LinkId = new ScenarioLinkId();
and this is properties for diagram
<vm:ScenarioDiagram x:Name="diagram" AlignToGrid="true" BorderThickness="5" AllowLinksRepeat="True"
BorderBrush="Black" ShapeBrush="LightBlue" BackBrush="#FFDCDCFF" ShowGrid="true" AllowInplaceEdit="true"
SnapToAnchor="OnCreate" Behavior="Custom" LinkCascadeOrientation="Horizontal" LinkHeadShape="Triangle"
DynamicLinks="True" CrossingRadius="90"
LinkCrossings="Straight" RouteLinks="True" LinkRouter="GridRouter" Bounds="0,0,1000,500"
AllowDrop="True" />
When I loaded custom diagram after using my custom classes, scenariolink hasn't any headshape.
so, I captured SaveToXml and LoadFromXml methods using debug mode.
And, I found that HeadShape property assigned null after base.LoadFromXml inside my override method, LoadFromXml, is executed.
But previous value was "Triangle", before base.LoadFromXml~ method's execution.
Below is my code..
How can I solve this problem?????
Re: custom diagram link lost headshape?
Reply #1 - Nov 4th, 2011 at 7:09am
We have this code in the LoadFromXml method:
if (context.ClassVersion > 1)
	baseShape = context.ReadShape("BaseShape", xmlElement, ArrowHeads.None);
	intermediateShape = context.ReadShape("IntermediateShape", xmlElement, ArrowHeads.None);
	headShape = context.ReadShape("HeadShape", xmlElement, ArrowHeads.None);
else
	headShape = ArrowHeads.HeadShapeFromOldId(context.ReadInt("HeadShape", xmlElement));
	baseShape = ArrowHeads.HeadShapeFromOldId(context.ReadInt("BaseShape", xmlElement));
	intermediateShape = ArrowHeads.HeadShapeFromOldId(context.ReadInt("IntermediateShape", xmlElement));
so you will have to specify at least 2 for the version-id  value when calling RegisterItemClass in order for the link to load shape identifiers by the new format.
It seems we should change the versioning implementation to let you use your own version numbers independent from those of the base classes. The largest version we have at this time is 4 for ContainerNode, so for now you could probably use some larger version identifiers (say starting from 100) to be on the safe side.
darby
Reply #2 - Nov 4th, 2011 at 8:01am
Hello Stoyo
it works
thanks a lot~~
