Normal Topic Image in Row Header of LaneGrid (Read 2147 times)
binuvc
Nov 9th, 2011 at 12:56pm
Is there a way to display image inside a lanegrid row/column header when we using
MindFusion.Diagramming.Silverlight.Lanes
Re: Image in Row Header of LaneGrid
Reply #1 - Nov 9th, 2011 at 2:03pm
You could modify the default header template and add an <image> along the current <textblock>: This is the default:
<Style TargetType="lanes:LaneGridHeaderPresenter">
	<Setter Property="Template">
		<Setter.Value>
			<ControlTemplate TargetType="lanes:LaneGridHeaderPresenter">
				<lanes:FourSidedBorder BorderStyle="{Binding Style}">
					<TextBlock Text="{Binding Title}" />
				</lanes:FourSidedBorder>
			</ControlTemplate>
		</Setter.Value>
	</Setter>
</Style>
where
xmlns:lanes="clr-namespace:MindFusion.Diagramming.Silverlight.Lanes;assembly=Min
dFusion.Diagramming.Silverlight". You'll probably have to place the textblock and image inside a stack or grid panel. Here's an example showing how to assign a custom style to headers:
http://mindfusion.eu/Forum/YaBB.pl?board=diaglite_disc;action=display;num=130623...
binuvc
Reply #2 - Nov 10th, 2011 at 5:27am
Thanks for the quick reply..
It helps me a lot.
Thanks once again.
