Normal Topic Unable to Move Node (Read 1798 times)
muthuhamid
Unable to Move Node
Nov 10th, 2011 at 10:13am
Hi Stoyo
I have some shapenodes in the diagram. Among these nodes one of the node's Height is 3. When i try to move this node using mouse, am unable to move. After i move, it comes back to its original position again. But if I change the height to greater than 6, then am able to move it.
When i create this node i did not assign any value to the HandlesStyle property as i left it to default value. Later i tried this property value with EasyMove and MoveOnly, nothing helped out.
And the events NodeModifying or NodeModified are not fired too.
I could not figure out the reason for this.
Could please help me in this regards?
Thanks and Best Regards
Muthu
Re: Unable to Move Node
Reply #1 - Nov 10th, 2011 at 10:31am
Hi Muthu,
It should be the same issue as here:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=130856441...
muthuhamid
Reply #2 - Nov 12th, 2011 at 11:18am
Hi Stoyo
Yes .. it is same issue got fixed now...
Thanks a lot..
Regards
Muthu
