Normal Topic Container Resized Problem (Read 1341 times)
lripple
Nov 10th, 2011 at 1:30pm
I was wondering if there was an event that is fired when you resize nodes out of a container?
I am using both ContainerChildAdded and ContainerChildRemoved, however these don't seem to be called if you resize a container to no longer contain the nodes.
Is there anyway to know what just got affected by the resize?
Re: Container Resized Problem
Reply #1 - Nov 10th, 2011 at 8:49pm
How have you managed to resize a container - doesn't it resize itself automatically to fit all its children? Even if you have overridden some method to allow manual resize, a child node probably won't detach automatically if the container is resized to no longer contains the child geometrically. Perhaps you should handle the NodeModified event raised for the container, and loop over its SubordinateGroup.AttachedNodes to call Remove for the ones that are no longer inside - i.e. when container.Bounds.Contains(child.Bounds) returns false.
