Normal Topic ShapeNode.Text could not display Chinese character (Read 5137 times)
winnor
Nov 17th, 2011 at 11:05am
I am trying the ShapeNode, I set the Text property of it to be Chinese Character string.  On the DiagramView, the string could not be shown.
Re: ShapeNode.Text could not display Chinese chara
Reply #1 - Nov 17th, 2011 at 11:13am
What Font and ClientSideMode values are you using?
winnor
Reply #2 - Nov 17th, 2011 at 11:51am
Stoyo, thanks for your reply.
here is,  this.diagramView.InplaceEditFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((System.Byte)(0)));
Reply #3 - Nov 17th, 2011 at 12:05pm
InplaceEditFont is not used to render ShapeNode's Text. If you are not setting the diagram's Font property, then you are probably with the default Arial font. In addition, what ClientSideMode value are you using? If it's ImageMap, check these topics:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=128754611...
http://mindfusion.eu/Forum/YaBB.pl?board=netdg_disc;action=display;num=127462984...
winnor
Reply #4 - Nov 17th, 2011 at 12:16pm
Stoyo,
Thanks a lot.
I did not set ClientSideMode. I could not find any poperty of DigramView or Diagram called ClientSideMode. I am using NETDiagram dlls.  Any idea?
Reply #5 - Nov 17th, 2011 at 12:19pm
ClientSideMode is a property of DiagramView. The default value is JavaApplet - do you see the Java cup logo where the diagram should appear while loading the page?
winnor
Reply #6 - Nov 17th, 2011 at 12:24pm
Stoyo,
Great thanks.
Finally, I set ShapeNod.Font = new Font("Arial Unicode MS", 8.25F);
Then all works.
