Normal Topic How to change size of ShapeNode with a same scaling? (Read 3416 times)
ncepu
Mar 6th, 2012 at 12:37pm
e.g. How to change the size of a square,but not change the  ratio when I change the ShapeNode?
Re: How to change size of ShapeNode with a same scaling?
Reply #1 - Mar 6th, 2012 at 12:58pm
Set node.Constraints.KeepRatio.
ncepu
Reply #2 - Mar 6th, 2012 at 1:54pm
I am sorry!
I still have a question,the code of you told me is the C# code,I want the javascript code.
Reply #3 - Mar 6th, 2012 at 3:24pm
node.getConstraints().setKeepRatio(true);
ncepu
Reply #4 - Mar 7th, 2012 at 1:10am
public NodeConstraints getConstraints ()
This is the getConstraints function.
But I still can not find the setKeepRatio(true)function in  NodeConstraints class.
Thank you very much!
Reply #5 - Mar 7th, 2012 at 6:44am
What version of the control are you using? This method was added to Java mode with the NetDiagram V4.1 release.
ncepu
Reply #6 - Mar 7th, 2012 at 8:24am
Thank you for reminding me!My version is not v4.1.
That is extremely helpfull!!
Thanks a lot!
