Normal Topic SwimLane implementation (Read 1640 times)
binuvc
Nov 17th, 2011 at 11:25am
Hi
It seems that swim lanes can be achieved by directly manipulating the LaneGrid property of the Diagram object.
How is the SwimLaneLayout different from this?
what additional feature do we get by implementing the swimlanelayout?
Also We had a scenario where we need to add lanes (rows and columns) dynamically, say , by clicking a button. Could you please provide some sample code to achieve this as well as the ISwimLaneGrid implementation..
Thanks in advance.
Re: SwimLane implementation
Reply #1 - Nov 17th, 2011 at 12:00pm
SwimlaneLayout will arrange nodes automatically along the LaneGrid lanes or your custom lanes. If nodes will be drawn by the user, you don't have to use the layout class.
You must implement the ISwimLaneGrid interface only if you need to use a custom grid and need to apply the SwimlaneLayout algorithm. You can create a custom grid by either composing it from locked background nodes, or by placing a grid control behind the diagram and setting the diagram's background to Transparent.
You can add a new row to the built-in grid like this:
private void OnAddRow(object sender, RoutedEventArgs e)
	diagram.LaneGrid.RowHeaders.Add(
		new Header("row " + diagram.LaneGrid.RowHeaders.Count));
