Normal Topic Loadfromxml is not loading xml file (Read 3367 times)
em
Jan 17th, 2012 at 8:38pm
I am using NetDiagrammer in asp.net. I have added the functionality to allow user to set titles for nodes and arrows. Once everything is set then this diagram is saved in xml format by calling savetoxml method. Later when i try to load this xml file using loadfromxml then I get the following error:-
[FormatException: Input string was not in a correct format.]
MindFusion.Diagramming.Diagram.LoadFromXml(XmlDocument document, Boolean loadDiagramProperties) +2459
MindFusion.Diagramming.Diagram.LoadFromXml(XmlDocument document) +42
MindFusion.Diagramming.WebForms.DiagramView.LoadFromXml(XmlDocument document) +55
MindFusion.Diagramming.WebForms.DiagramView.LoadFromXml(String fileName) +82
Any help would be appreciated.
Re: Loadfromxml is not loading xml file
Reply #1 - Jan 18th, 2012 at 10:52am
Are you storing these titles as Tag values? Could you attach the file here or email it to support@mindfusion.eu?
em
Reply #2 - Jan 18th, 2012 at 6:38pm
No, I am not storing these values as tag values rather I am just setting the text property of each node and link and then call savetoxml method to save it. I am attaching the xml file here.
AnotherTest.txt (Attachment deleted)
em
Reply #3 - Jan 18th, 2012 at 6:57pm
I have figured it out. Actually I am using tag to serialize some information. Once I have removed the tag information then it started working fine. Can you please tell me what is wrong with the following tag information in the file?
<Tag>ModelInformation;54;</Tag>
Reply #4 - Jan 19th, 2012 at 8:26am
Are you handling the DeserializeTag event, and what does the handler look like?
em
Reply #5 - Jan 19th, 2012 at 2:50pm
No, I was just loading the file without deserializing it. Perhaps, this is a problem. Thanks
Reply #6 - Jan 19th, 2012 at 7:15pm
Our developer reproduced the exception loading the attached file and thinks it happens if you use custom SerializeTag handler without a reciprocal DeserializeTag. The problem is that the standard tag serialization code writes a "Type" attribute, and the deserialization code tries to read that attribute and parse it as an int value. If the <Tag> elements was saved by SerializeTag handler, that attribute is not there and the built-in deserialization code cannot load the tag. So handling DeserializeTag should fix the problem.
