Normal Topic Zoom to centre (Read 2030 times)
jagdipa
Zoom to centre
Jan 18th, 2012 at 2:19pm
I have a diagram with a silder for zooming in and out. My issue is that the zoom is anchored to the top left of the diagram. How do I get the zoom to be anchored to the centre middle of the diagram?
Re: Zoom to centre
Reply #1 - Jan 18th, 2012 at 3:33pm
Use this method:
void SetZoomFactor(double zoomFactor, Point anchor)
	var pivot = DocToClient(anchor);
	var scroll = DocToClient(new Point(diagram.ScrollX, diagram.ScrollY));
	var offset = new Point(pivot.X - scroll.X, pivot.Y - scroll.Y);
	diagram.ZoomFactor = zoomFactor;
	offset = ClientToDoc(offset);
	diagram.ScrollX = anchor.X - offset.X;
	diagram.ScrollY = anchor.Y - offset.Y;
Point DocToClient(Point point)
	return diagram.DocumentPlane.TransformToVisual(diagram).Transform(point);
Point ClientToDoc(Point point)
	return diagram.TransformToVisual(diagram.DocumentPlane).Transform(point);
private void OnMouseWheel(object sender, MouseWheelEventArgs e)
	SetZoomFactor(
		diagram.ZoomFactor + e.Delta / 20.0,
		e.GetPosition(diagram.DocumentPlane));
void OnKeyDown(object sender, KeyEventArgs e)
	var v = diagram.Viewport;
	var center = new Point(v.X + v.Width / 2, v.Y + v.Height / 2);
	switch (e.Key)
		case Key.Add:
			SetZoomFactor(diagram.ZoomFactor * 1.2, center);
			break;
		case Key.Subtract:
			SetZoomFactor(diagram.ZoomFactor / 1.2, center);
			break;
