Normal Topic Point dragging (Read 4655 times)
RallyTronics LLC
Point dragging
Jan 19th, 2012 at 8:08pm
In my application I would like the user to have the ability to drag points on a line graph (vertical only) to change the value.  Is this possible with your component?
Re: Point dragging
Reply #1 - Jan 19th, 2012 at 8:34pm
It's not possible at this time. Our developer will try to implement this in the next few days, it shouldn't be much work.
RallyTronics LLC
Re: Point dragging
Reply #2 - Jan 20th, 2012 at 6:53am
great service, thanks!
Re: Point dragging
Reply #3 - Jan 25th, 2012 at 11:06am
Please check this version:
https://mindfusion.eu/_beta/wpfchart131.zip
In order to allow drag of a chart point along the Y-axis, set the Behavior property to AllowYDrag:
chart.Behavior = Behavior.AllowYDrag;
We have also added a HitTestDistance property, specifying the radius of the area around a point where dragging with the mouse will start moving that point.
