Normal Topic How not to show values on mouseover in BarChart (Read 5653 times)
PNJ
Mar 29th, 2016 at 4:18pm
When I move the mouse over my BarChart, the value (x, y) show in a small white rectangle. How do I disable this feature?
IsHitTestVisible = false, does work but it also disables the possibility to click on the bar. I want the click feature. So no option for me.
Any suggestions?
Kinds regards,
Paul,
the Netherlands
Re: How not to show values on mouseover in BarChart
Reply #1 - Mar 29th, 2016 at 4:44pm
Set CrossHairType = CrossHairType.ShowCrosshair to only show the crosshairs without values, or ShowCrossHair = false to hide it completely.
PNJ
Reply #2 - Mar 30th, 2016 at 7:49am
The settings you suggest are my current settings. So this is not the solution unfortunately. Do you have another idea?
Even worse: the application crashes when I set ShowCrossHair="True". Error: "Specified argument was out of the range of valid values.\r\nParameter name: index"
Kinds regards,
Paul,
the Netherlands
Reply #3 - Mar 30th, 2016 at 8:38am
That might be a tooltip - try setting Series.ToolTipType = ToolTipType.Custom or Empty; If you set it to Custom, the control will display ToolTipText which is null by default.
PNJ
Reply #4 - Mar 30th, 2016 at 12:27pm
Thanks, that's it. Smiley
Kinds regards,
Paul,
the Netherlands
Reply #5 - Mar 31st, 2016 at 9:26am
Hi Paul,
We could not reproduce that, any chance for you to send us your chart initialization code?
