Normal Topic Any chance of a 3D surface in the near future? (Read 9060 times)
MotoCon
Apr 29th, 2012 at 3:06am
I need a 3D surface graph in WPF, anything in the pipeline?
Re: Any chance of a 3D surface in the near future?
Reply #1 - Apr 30th, 2012 at 6:12am
By 3D surface, do you mean plotting a function of 2 variables, e.g. z = f(x,y), or an arbitrary surface defined by a system of equations?
MotoCon
Reply #2 - May 1st, 2012 at 7:19pm
I have a x and y axes defining an unevenly spaced grid and a z value at each point.  Is is similar to a height-map but not evenly spaced.
Reply #3 - May 2nd, 2012 at 5:58am
Ok, our developers will try to implement this in the next few weeks.
Reply #4 - Jul 19th, 2012 at 3:09pm
You can find initial implementation of surface chart attached, along with sample project showing how to use it.
SurfaceChartSample.zip (Attachment deleted)
