Normal Topic box creation restriction (Read 1984 times)
JDogggieIII
Jan 31st, 2012 at 8:33pm
I have a flowchart.net instance in my C# application.  At one point during the user workflow I would like them to be able to move arrows around, but not for them to be able to create new nodes.  I have spent a good amount of time trying to find a way to restrict the user from creating new boxes but have been unsuccessful.  Is there any way to do this while still allowing them to move arrows around?
Many thanks in advance.
Re: box creation restriction
Reply #1 - Feb 1st, 2012 at 8:11am
You could call e.CancelDrag() from the NodeCreating handler. That should also be possible by setting EnabledHandles = None on all nodes, or setting DiagramView.Behavior to CreateLinks.
JDogggieIII
Reply #2 - Feb 2nd, 2012 at 2:52pm
Hi Stoyan,
Thanks for the info.  One further question since I am new to this FlowChart .Net scene...
I'm assuming I must override the handler in order to call e.CancelDrag() (or make any changes to it's behavior).  However, I am struggling with this.  I've overridden things before without issue, so perhaps it's my lack of sleep or broken brain  Cheesy.  Do you perhaps have any example code for this sort of thing?
Reply #3 - Feb 2nd, 2012 at 3:34pm
If you have placed the Diagram object on a form, select it in the form designer, open the property window, switch to the event list and double-click NodeCreating to create an event handler.
If you create a Diagram from code, you could add a NodeCreating hanlder like this:
diagram.NodeCreating += OnNodeCreating;
void OnNodeCreating(object sender, NodeValidationEventArgs e)
    e.CancelDrag();
JDogggieIII
Reply #4 - Feb 4th, 2012 at 8:46pm
Hi Stoyen,
Thank you.  That was very helpful.  I am now able to achieve what i was trying to do.
Thanks again.
