Normal Topic Text is clipped with all shapes besides rectangles (Read 1137 times)
msperling
Feb 8th, 2012 at 11:10pm
We are creating graphs with nodes and links.  There is text inside the nodes.  When we try setting the shapenode.shape property to anything but rectangle, even to rounded rectangle, the text is sometimes clipped. We have tried setting TextPadding, but that makes the situation worse.  What should we do about this? Rectangles are boring.
Mike
Re: Text is clipped with all shapes besides rectangles
Reply #1 - Feb 9th, 2012 at 8:44am
If you mean the text is laid out in the node's bounding rectangle and the current shape's outline clips it, you can enable ShapeNode.PolygonalTextLayout to make the text arranged according to the actual shape outline.
