Normal Topic Add scroll to ShapeNode (Read 1244 times)
winTW
Feb 12th, 2012 at 8:29pm
Hi
I have a ShapeNode that contains a lot of text.
Is it possible to add it a - scroll ?
Thanks in advance!
Re: Add scroll to ShapeNode
Reply #1 - Feb 13th, 2012 at 7:46am
There's no built-in text scrolling available for ShapeNodes at this time. You could probably attach a ControlNode hosting a scrollbar to the ShapeNode and then draw the scrolled text yourself using custom drawing. Or if you are going to use ControlNodes anyway, you might directly host TextBoxes with vertical scrolling enabled.
Another option could be to call BeginEdit when a node is clicked or pointed by the mouse to show its scrollable in-place edit box or your custom control.
winTW
Reply #2 - Feb 15th, 2012 at 7:11pm
Thank you very much !
I replace the ShapeNode with ControlNode and it works Perfectly .
