Normal Topic Diagram.Nodes.Remove also removes links (Read 1817 times)
jackalexander
Mar 1st, 2012 at 12:54pm
It seems that if I delete nodes from a diagram, it automatically removes any links that are attached to the node.  Is this behaviour by design?
Re: Diagram.Nodes.Remove also removes links
Reply #1 - Mar 1st, 2012 at 1:25pm
In most applications of graphs, links make no sense without nodes (they are defined as an ordered pair of nodes in the mathematical graph model) so they are removed by default. You might try setting a link's Origin or Destination to null before removing its respective node so that the link remains in the diagram. The control will actually associate the link with a DummyNode object in this case, and also when AllowUnconnectedLinks is enabled and the users draw an unconnected link. So if you need to find out whehter a link is disconnected, you must compare the type of its nodes with DummyNode.
