Normal Topic How can i Bind ControlNode BoundsProperty? (Read 3008 times)
chiru29
Mar 2nd, 2012 at 2:38pm
In my object model i have 4 properties like XPosition, YPosition, Width & Height. How can i bind these to ControlNode with Dependency Property? Can i use BoundsProperty?
If possible, Can you please provide me a code snippet for this?
Chiranjeevi
Re: How can i Bind ControlNode BoundsProperty?
Reply #1 - Mar 5th, 2012 at 8:10am
Such kind of binding is already implemented in the VirtualizingDiagram control.
If you prefer using the Diagram control, you could add a Bounds property to the model that returns Rect(XPosition, YPosition, Width, Height) instance and raise INotifyPropertyChanged.PropertyChanged("Bounds") whenever any of these 4 properties change.
Alternatively, you might try using a multi-binding solution:
http://www.scottlogic.co.uk/blog/colin/2010/05/silverlight-multibinding-solution...
chiru29
Reply #2 - Mar 5th, 2012 at 1:37pm
Thanks Stoyon. I will try this.
thanks,
Chiru
