Normal Topic Layout.Arrange arranges the elements in the order in which they were added (Read 3169 times)
binuvc
Mar 29th, 2012 at 8:01am
When we invoke layout.Arrange() on a diagram, it arranges the nodes in the order in which they were added in to the diagram.
Is there any way to keep the order and arrange in the current order itself? (We need to rearrange the nodes and then apply layout.)
Thanks in advance.
BinuVC
Re: Layout.Arrange arranges the elements in the order in which they were added
Reply #1 - Mar 29th, 2012 at 10:34am
Which layout class does that?
binuvc
Reply #2 - Mar 29th, 2012 at 10:52am
TreeLayout arranges the nodes at a particular level in the order they were added to the diagram.
BinuVC
Reply #3 - Mar 29th, 2012 at 12:41pm
The order of a node's children when using TreeLayout depends on the position of links in its OutgoingLinks collection. If you need the child nodes to be arranged in a particular order, you will have to set the same order for the links within the parent's OutgoingLinks.
