Normal Topic AnchorPattern can not create more than once (Read 1747 times)
ncepu
Mar 7th, 2012 at 11:56am
ClientSideMode:JavaApplet,
One is:In onLoad fuction,I want to define a AnchorPattern.
e.g.
Code (Javascript)
 pattern_Bus=scripthelper.createAnchorPattern("Bus");
When I first load the page,there is no problem.But when I refresh the page,there is a problem.
Warning:Java: java.lang.IllegalArgumentException: The AnchorPattern string identifier must be unique.
I want your helpe!Thank you.
Re: AnchorPattern can not create more than once
Reply #1 - Mar 8th, 2012 at 7:06am
Try this:
pattern_Bus=scripthelper.anchorPatternFromId("Bus");
if (!pattern_Bus)
    // add points
ncepu
Reply #2 - Mar 8th, 2012 at 7:16am
I solved it.When I define it,I do not specify it's identity.It's amazing!
Thank Stoyan very much!
