Normal Topic a small problem about diagramView (Read 1738 times)
webdev
Nov 28th, 2012 at 1:24pm
when i layout mousedown-drag-mouseup on the diagramView , a new rectangle will be created. how to stop it? any properties?
Re: a small problem about diagramView
Reply #1 - Nov 28th, 2012 at 2:14pm
Change the DiagramView.Behavior property. Its default value LinkShapes lets you draw new ShapeNode and DiagramLink objects. You could set Behavior = DrawLinks to allow only drawing new links, e.g. if nodes will be created via drag and drop. Other values you might try are Modify to allow only selecting and moving items, or DoNothing if you need to show a read-only diagram.
