Normal Topic Box - Mouse Movement (Read 2800 times)
jcincanton
Mar 20th, 2012 at 2:08pm
In the demo program, the very first simple flow diagram shows selection handles when the cursor is moved over a box (or other shape).
How is this accomplished? Is there a property setting or was this done programatically?
Thanks for the answer.
Re: Box - Mouse Movement
Reply #1 - Mar 20th, 2012 at 2:26pm
I think the demo shows anchor points when the mouse hovers over a node; you can set ShowAnchors = saAuto to get that effect. If you need the same for adjustment handles, set ModificationStart = mdAutoHandles.
jcincanton
Reply #2 - Mar 20th, 2012 at 2:44pm
The modificationstart property works great. Thanks for the rapid response.
