Normal Topic Problem of slowness when moving in a graph (Read 3231 times)
JR
Mar 27th, 2012 at 9:42am
I have a feedback from a customer when we are using the ActiveX 5.4.
In a graph, when we are moving with the mouse in the bottom of the document the move is very slow and the selection of a box also. I think it is a redraw problem of your activex.
More you go to the bottom of the graph, more the moving are longs.
I am using Powerbuilder but I have reproduced the problem with you VB Flowcharter sample. I send you a file containing the graph saved with the SaveToFile method. You can try yourself in you VB sample opening the same file. The graph is in the attached file.
Can you do something to optimize your activeX ?
Regards
PS : sorry for my english....
graph.zip (Attachment deleted)
Re: Problem of slowness when moving in a graph
Reply #1 - Mar 27th, 2012 at 10:18am
It seems dashed lines are drawn very slowly by GDI+, and there are more of them at the bottom of your flowchart. You could either use the geClassic graphics mode, or set the links PenStyle to psSolid in order to improve the rendering speed.
JR
Reply #2 - Mar 27th, 2012 at 11:00am
I have to keep the dash style for the lines.
So I have disabled the GDI+ graphics mode.
I have also put the textstyle to tsCenterML instead of tsCenter. It seems that GDI+ manage correctly the CRLF characters.
And now, it works !!
