Normal Topic Viewing properties of custom nodes in the property grid (Read 3807 times)
newbieDraw
Apr 2nd, 2012 at 2:43pm
Hi Stoyo,
Is it possible to view and set properties for custom node types (some string and numeric values) in the property grid, during runtime. I am trying to set the selected node as the object for property grid but it doesn't work.
Re: Viewing properties of custom nodes in the property grid
Reply #1 - Apr 2nd, 2012 at 4:40pm
Are your custom properties public? I think the property grid displays only public properties.
newbieDraw
Reply #2 - Apr 2nd, 2012 at 4:49pm
Hi Stoyo,
Find the code snippets attached. The properties are public.
public class cNode : ShapeNode
        public string label;
        public string Label
            get { return label; }
            set { label = value;}
private void diagram1_NodeSelected(object sender, NodeEventArgs e)
            DiagramNode node = e.Node;
            cNode cnode = node as cNode;
            propertyGrid1.SelectedObject = cnode;
newbieDraw
Reply #3 - Apr 2nd, 2012 at 5:32pm
Also, when I create a new cNode object in my form constructor, the property grid shows the custom properties. However, it doesn't show for the specific nodes that are created within diagramView.
Reply #4 - Apr 2nd, 2012 at 6:06pm
Do you mean nodes drawn with the mouse don't have these properties? That probably happens because the nodes are ShapeNode instances. You will have to set Behavior = Custom and CustomNodeType = typeof(cNode) to enable drawing custom nodes.
newbieDraw
Reply #5 - Apr 2nd, 2012 at 6:44pm
I had set Behavior = Custom and CustomNodeType = typeof(cNode) to enable drawing custom nodes. It didn't work. Let me know if you have any other ideas. I will try to troubleshoot.
Reply #6 - Apr 3rd, 2012 at 6:24am
The IconNodes sample project sets Behavior and CustomNodeType the same way. Adding a property grid to it shows the new properties of IconNode objects - Label and Icon. Check if your Behavior value doesn't change to DrawShapes or LinkShapes later, e.g. it might reset to LinkShapes if you load a file using DiagramView.Load methods.
