Normal Topic Upload XML file failed! (Read 2945 times)
ncepu
Apr 21st, 2012 at 7:02am
ClientSide Mode:JavaApplet
question .When I first load my diagram from a xml file,the diagram display the rectangle instead my shapenode.After several times,it can display the correct shapenode.
How Can I solve,I hope your help.
Thank you!
« Last Edit: Apr 22nd, 2012 at 2:54am by ncepu »
Re: Upload XML file failed!
Reply #1 - Apr 23rd, 2012 at 5:51am
How are you loading your custom shape definition on the client side?
ncepu
Reply #2 - Apr 25th, 2012 at 11:33am
I load my file on the server side in PageLoad function.And before I load the xml file ,I set the diagramView‘s shapeLiabrary atrribute to my shapeLibrary file.
Reply #3 - Apr 25th, 2012 at 12:47pm
Please attach a test project that shows the problem.
ncepu
Re: Load XML file failed!
Reply #4 - Apr 27th, 2012 at 4:23am
This is the Test project!It load the file failed.I can't upload all my project to the server,because it's so big,so,I upload the important files.
I need your help!
Test.rar (Attachment deleted)
Reply #5 - Apr 27th, 2012 at 5:05am
You could set ShapeLibraryLocation in the aspx markup, move the assignment to Page_Init, or call ShapeLibrary.LoadFrom(MapPath("PowerSystem.shl")) before diagram.LoadFromXml(). The problem is that on the server side custom shapes specified via ShapeLibraryLocation are loaded from the control's OnInit handler; the assignment in Page_Load comes too late and will only help loading the shapes in the applet.
