Normal Topic LayeredLayout overlapping nodes (Read 1643 times)
henry k
Apr 26th, 2012 at 7:59am
Is there possibility to prevent ndoes from overlapping each and other?
For instance, in container node there are other containerNodes and shapenodes within the "main" container... problem is that shapenodes that are not related to inner container(s) are overlapping the containers (see attachment).
(the N1 shouldn't be over Container3; should be above it or somewhere else... {N1 is NOT Attached to Container3})
Br. Henry
Re: LayeredLayout overlapping nodes
Reply #1 - Apr 26th, 2012 at 11:49am
If you are using LayeredLayout to arrange the container's children, try setting the layout.IgnoreNodeSize property to false.
henry k
Reply #2 - Apr 27th, 2012 at 12:13pm
Thank you, that did the thing.
