Normal Topic How to SaveToFile and LoadFromFile the Custom Node Type? (Read 1610 times)
GoldyWang
May 22nd, 2012 at 3:28pm
I save the custom nodes in file, and load then from the file, they are not the custom nodes as i wish them to be. they are just the plain ShapeNode type instance.
My Custom Type coding like this:
(Followed the developer guide, the types override the SaveTo and LoadFrom methods)
public class TShapeNode : ShapeNode
protected override void SaveTo(System.IO.BinaryWriter writer, PersistContext ctx)
base.SaveTo(writer, ctx);
// Save the label using the standard .NET BinaryWriter
//writer.Write(label);
//// Save the image using the built-in image saving code,
//// which stores the contents of shared images only once.
//ctx.SaveImage(icon);
protected override void LoadFrom(System.IO.BinaryReader reader, PersistContext ctx)
base.LoadFrom(reader, ctx);
//label = reader.ReadString();
//icon = ctx.LoadImage();
public class TPlace : TShapeNode
and the creating node, is coded as following:
node = new TPlace(diagram);
node.Text = "p";
diagram.Nodes.Add(node);
RectangleF bounds = node.GetBounds();
bounds.Location = pt;
node.SetBounds(bounds, false, false);
I am on .NET Diagramming v5.8
is there something more i should do?
Re: How to SaveToFile and LoadFromFile the Custom Node Type?
Reply #1 - May 23rd, 2012 at 7:19am
Call the RegisterItemClass method. E.g. the IconNodes sample project that you copied some code from does this in the MainForm constructor:
Diagram.RegisterItemClass(typeof(IconNode), "IconNode", 1);
GoldyWang
Reply #2 - May 23rd, 2012 at 7:57am
thanks, Diagram.RegisterItemClass works
        static TShapeNode()
            Diagram.RegisterItemClass(typeof(TShapeNode), "TShapeNode", 1);
