Normal Topic unable to load the file (Read 3285 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Jun 8th, 2012 at 9:22am
when i am trying to load the file in diagram using diagram.LoadFromFile(loadfilename);
it is throwing the error message as "unable to read beyond the end of the stream"
kindly help
if you want something then go and grab it
Re: unable to load the file
Reply #1 - Jun 8th, 2012 at 9:49am
Was this file created using SaveToFile?
madhan1
FROM EVERY ONE ..
Reply #2 - Jun 8th, 2012 at 11:22am
yes
Reply #3 - Jun 8th, 2012 at 12:40pm
Please attach it here.
madhan1
FROM EVERY ONE ..
Reply #4 - Jun 14th, 2012 at 10:42am
Dear stoyo,
i have attached the file..kindly check
01_pnr.rar (Attachment deleted)
Reply #5 - Jun 14th, 2012 at 12:37pm
This file was truncated somehow. The header shows there were 120 items in this diagram, but the loading code reaches the end of the file while reading the 58th item (a table). All data loaded before that seems correct, so if it's something important, we can extract the first 57 items for you. Most of them seem to be links though.
It's not likely SaveToFile to return successfully if it stopped writing at the middle of an item. It should have thrown an exception of some kind, say IOException("disk full"). You might check if you are not catching and ignoring exceptions, you should report them to users instead.
If SaveToFile completed successfully, the problem could have happened because of a system crash or power outage before the HDD cache was written, or say if the file was sent as email attachment and there was a transmission error.
madhan1
FROM EVERY ONE ..
Reply #6 - Jun 15th, 2012 at 5:04am
thanks stoyo.
