Hot Topic (More than 10 Replies) scroll the screen using mouse (Read 8350 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Jun 18th, 2012 at 9:21am
Dear team,
              i want to scroll the screen using mouse other than horizontal & vertical bar.
kindly help me.
if you want something then go and grab it
Re: scroll the screen using mouse
Reply #1 - Jun 18th, 2012 at 10:13am
Setting DiagramView.Behavior = Pan will let you scroll by dragging any part of the view with the mouse. If you prefer to scroll from the MouseWheel handler, it should look like this:
void diagramView_MouseWheel(object sender,
                             MouseEventArgs args)
            float newScrollY = diagramView.ScrollY - args.Delta / 50;
            if (newScrollY > diagram.Bounds.Top)
                        diagramView.ScrollY = newScrollY;
madhan1
FROM EVERY ONE ..
Reply #2 - Jun 18th, 2012 at 12:58pm
thanks stoyan,
         but i want drag and move with horizontal & vertical
Reply #3 - Jun 18th, 2012 at 6:56pm
Sorry, I cannot understand that.
madhan1
FROM EVERY ONE ..
Reply #4 - Jun 19th, 2012 at 4:17am
dear stoyan,
           when i use DiagramView.Behavior=pan; i can not  create / select the links.but my need is
1. if i click on the node i allow to create the links.
2. if i am just dragging on diagram view then i have to scroll horizontal & vertical
Reply #5 - Jun 19th, 2012 at 7:05am
Call diagram.GetNodeAt from DiagramView.MouseMove handler and toggle Behavior between DrawLinks / Pan depending on whether there's any node at the mouse position.
madhan1
FROM EVERY ONE ..
Reply #6 - Jun 20th, 2012 at 5:45am
Dear stoyan,
thanks a lot. but having trouble with tables & links. now i am trying with getitemat
the code is here
Point f = new Point(e.X, e.Y);
if(diagram.GetItemAt(f,false)!=null)
diagramView.Behavior = Behavior.DrawLinks;
else
diagramView.Behavior = Behavior.Pan;
some time i cannot get the link to be selected in tables Embarrassed
Reply #7 - Jun 20th, 2012 at 7:22am
If (e.X,e.Y) is the mouse position you get in MouseMove handler, you will have to convert it from pixels to diagram coordinates using the DiagramView.ClientToDoc method. Otherwise GetItemAt will not return the correct object.
madhan1
FROM EVERY ONE ..
Reply #8 - Jun 20th, 2012 at 7:34am
Thanks stoyan,
        it works  now Smiley
madhan1
FROM EVERY ONE ..
Reply #9 - Jul 4th, 2012 at 6:35am
Dear stoyan,
               now i cann't drag the node after the visible of diagram view. i have manually drag the diagram view and then move the nodes.
Reply #10 - Jul 4th, 2012 at 7:24am
Enable the AutoScroll property and the DiagramView should scroll automatically when you drag a node toward the view's edge.
madhan1
FROM EVERY ONE ..
Reply #11 - Jul 4th, 2012 at 7:54am
Dear stoyan,
        i have already enabled the autoscroll = true in diagram view. if i drag the  mouse with out the node then the diagramview is moving on the edge but if i drag with the node then it is not working
madhan1
FROM EVERY ONE ..
Reply #12 - Jul 5th, 2012 at 7:08am
dear stoyan,
          kindly help i am waiting for you advice.
Reply #13 - Jul 5th, 2012 at 5:49pm
I can see nothing like this in my test app. Try adding your initialization and event handling code to the attached test project to find out what causes it.
AutoScrollTest.zip (Attachment deleted)
madhan1
FROM EVERY ONE ..
Reply #14 - Jul 6th, 2012 at 7:20am
Thanks Stoyan,
your code is working fine when it is in normal mode. when i maximize the form it is not working.
FYI :
i am using "FlowChart.NET component, version 5.3.3" and my insulation does n't have have the MindFusion.Scripting.dll .
