Normal Topic scroll the screen to node location (Read 4191 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Jul 7th, 2012 at 6:04am
Dear stoyan,
            when i click the link i want to move my screen to the Node location.  i have return the following code.
             ShapeNode destination =(ShapeNode) e.Link.Destination;
            diagramView.ScrollTo(destination.Bounds.X, destination.Bounds.Y);
this scroll the diagramview up to the left edge.
kindly advise me.
if you want something then go and grab it
Re: scroll the screen to node location
Reply #1 - Jul 9th, 2012 at 8:36am
This will center the link's destination in the view:
PointF destCenter = e.Link.Destination.GetCenter();
SizeF viewportSize = diagramView.ClientToDoc(
	diagramView.ClientRectangle).Size;
	destCenter.X - viewportSize.Width / 2,
	destCenter.Y - viewportSize.Height / 2);
madhan1
FROM EVERY ONE ..
Reply #2 - Jul 10th, 2012 at 4:54am
Thanks stayon,
                    i want to move my cursor also to move that place.if possible i want to move the cursor over the link.
Reply #3 - Jul 10th, 2012 at 7:08am
You will have to use the win32 SetCursorPos function, which takes screen coordinates:
[DllImport("user32.dll")]
static extern bool SetCursorPos(int X, int Y);
You can convert from diagram to screen coordinates by calling the view's DocToClient and PointToScreen methods.
madhan1
FROM EVERY ONE ..
Reply #4 - Jul 10th, 2012 at 10:34am
Dear stoyan,
i have follow this code
PointF p=new PointF(destination.Bounds.X,destination.Bounds.Y);
            Point p1 = new Point(diagramView.DocToClient(p).X, diagramView.DocToClient(p).Y);
            Point p2=  PointToScreen(p1);
            SetCursorPos(p2.X, p2.Y);
is it correct method
Reply #5 - Jul 10th, 2012 at 10:55am
Currently you are calling the form's PointToScreen method. You should call diagramView.PointToScreen(), since p1 is relative to the view:
PointF p = destination.Bounds.Location;
Point p1 = diagramView.DocToClient(p);
Point p2 = diagramView.PointToScreen(p1);
madhan1
FROM EVERY ONE ..
Reply #6 - Jul 10th, 2012 at 12:19pm
Thanks a lot stoyan
