Normal Topic How to know nodes are cutty? (Read 5173 times)
Taivan
Jun 28th, 2012 at 8:05am
thnx.
Re: How to know nodes are cutty?
Reply #1 - Jun 28th, 2012 at 10:05am
What do you mean by "cutty nodes"?
Taivan
Reply #2 - Jun 28th, 2012 at 10:24am
Stoyo wrote on Jun 28th, 2012 at 10:05am:
I m sorry my bad english. Please see the pic.
Thanks Stoyan.
Reply #3 - Jun 28th, 2012 at 1:15pm
You can check if (node1.Bounds.Intersect(node2.Bounds) != Rect.Empty) to find out if the nodes intersect.
Taivan
Reply #4 - Jun 29th, 2012 at 1:44am
Stoyo wrote on Jun 28th, 2012 at 1:15pm:
thanks Stoyan
But syntax error :
Error      11      Operator '!=' cannot be applied to operands of type 'void' and 'System.Windows.Rect'
Reply #5 - Jun 29th, 2012 at 7:21am
Ok, you will have to use a separate Rect variable:
Rect rect = node1.Bounds;
rect.Intersect(node2.Bounds);
if (rect != Rect.Empty) ...
