Normal Topic annotate diagrams/shapes (Read 1478 times)
Shiju
Jun 29th, 2012 at 1:26pm
Hi
     I am currently evaluating WPF diagram for my company. Is there any way i can annotate( add some comments ) in the diagram by clicking anywhere on the diagram?
    Also do you have more samples(including c# source code) for TreeLayouts and FlowChartlayouts?
thanks,
-Shiju
Re: annotate diagrams/shapes
Reply #1 - Jun 29th, 2012 at 2:33pm
There are no special annotation objects in the library. You could use ShapeNodes for that, and set their AllowIncoming / AllowOutgoingLinks properties to false in order to prevent users from drawing links to the annotations. So adding an annotation when the diagram is clicked could look like this:
private void OnDiagramClicked(object sender, DiagramEventArgs e)
	if (e.MouseButton == MouseButton.Left)
		var rect = new Rect(e.MousePosition, new Size(0, 0));
		rect.Inflate(40, 30);
		var annotation = diagram.Factory.CreateShapeNode(rect);
		diagram.BeginEdit(annotation);
Tree and Flowchart layouts are shown in the following samples: DirTree, JavaScript, TreeLayout. In addition, the custom layout code shown in WorkflowDesigner is what later became FlowchartLayout - you could use it as a base of your custom layout class to add support for more types of code statements.
