Hot Topic (More than 10 Replies) shadow for a Node (Read 6563 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
shadow for a Node
Jul 13th, 2012 at 10:52am
Dear Stoyan,
               how to draw a shadow for a selected node.
if you want something then go and grab it
Re: shadow for a Node
Reply #1 - Jul 13th, 2012 at 11:26am
You can enable shadows by setting Diagram.ShadowsStyle. If you need to hide them for some nodes, set the nodes' ShadowOffset to 0.
madhan1
FROM EVERY ONE ..
Reply #2 - Jul 16th, 2012 at 5:31am
Thanks stoyan,
         but i need to show the shadow only for the selected node.
Reply #3 - Jul 16th, 2012 at 9:24am
You will have to show and hide the shadow from respectively the NodeSelected and NodeDeselected event handlers, similarly to what you did for selection highlight earlier.
madhan1
FROM EVERY ONE ..
Reply #4 - Jul 17th, 2012 at 7:29am
Dear stoyan,
  i am using the following code.but it is not working.
node_selected event
     diagram.ShadowsStyle = ShadowsStyle.OneLevel;
             e.Node.ShadowColor = Color.Gold;
             e.Node.ShadowOffsetX = 5;
             e.Node.ShadowOffsetY = 5;
madhan1
FROM EVERY ONE ..
Reply #5 - Jul 18th, 2012 at 10:51am
any suggestions for me...
Reply #6 - Jul 18th, 2012 at 6:11pm
Use the ZOrder shadow style if the diagram contains some large background node - otherwise it will hide the shadows of nodes that are in front of it.
madhan1
FROM EVERY ONE ..
Reply #7 - Jul 19th, 2012 at 4:35am
Dear Stoyan,
        As your suggestion i have used Zorder . but still not working.
diagram.ShadowsStyle = ShadowsStyle.ZOrder;
             e.Node.ShadowOffsetX = 25;
             e.Node.ShadowOffsetY = 25;
FYR i have added the screen shot
Reply #8 - Jul 19th, 2012 at 9:02am
If that's a ShapeNode, you will have to set Transparent=false to show the shadow.
madhan1
FROM EVERY ONE ..
Reply #9 - Jul 19th, 2012 at 9:27am
sorry stoyan,
          e.Node does n't have Transparent property
Reply #10 - Jul 19th, 2012 at 5:00pm
Typecast e.Node to ShapeNode to access that property:
ShapeNode shape = (ShapeNode)e.Node;
shape.Transparent = ...
madhan1
FROM EVERY ONE ..
Reply #11 - Jul 20th, 2012 at 6:33am
Thanks Stoyan,
             i tried, i is working on TableNode but not in ShapeNode
Lyubo
MindFusion team
Reply #12 - Jul 20th, 2012 at 8:48am
You can find attached to this post the Telephony sample from the FlowChart.NET release, with minor adjustments that show how to enable shadows on ShapeNodes on selection. It uses the settings you've provided above. It's working fine on my system (with FlowChart.NET 5.3.3).
private void diagram_NodeSelected(object sender, NodeEventArgs e)
  ShapeNode node = e.Node as ShapeNode;
  if (node != null)
    node.Transparent = false;
    node.ShadowColor = Color.Gold;
    node.ShadowOffsetX = 5;
    node.ShadowOffsetY = 5;
Telephony.zip (Attachment deleted)
madhan1
FROM EVERY ONE ..
Reply #13 - Jul 20th, 2012 at 10:01am
Thanks a lot Lyubo...
