Normal Topic DiagramView Auto scrolling to 0, 0 diagram location (Read 3268 times)
rnpayet
Jul 18th, 2012 at 2:29am
Hi
We are having issue with DiagramView.
When we do a zoomToFit we get the diagram to center in the view are we want to.
As soon as the diagram is re size e.g    via a node drag.  The diagram jumps and align left .
It there any way of preventing this
Re: DiagramView Auto scrolling to 0, 0 diagram location
Reply #1 - Jul 18th, 2012 at 10:11am
At this time the only way to prevent that is to set diagram.Bounds to be at least as large as the view.
jf2020
I love FlowChart!
Reply #2 - Jul 23rd, 2012 at 3:23pm
Stoyan,
Can you please elaborate a bit more on this answer and explain what the various properties Bounds, viewport, extent, in diagram and diagramView mean exactly and how they behave.  I have tried to implement something similar where I want the drawing area to always be in the middle of the visible area when zooming out (i.e. I don't want 0,0 to stay at the upper left corner) similar to Power Point but I have had lots of trouble with this.  So A good explanation would be very welcomed.
JF
Reply #3 - Jul 24th, 2012 at 6:15am
Resizing the diagram to fill the view after calling ZoomToFit can be implemented like this:
private void zoomToFitToolStripMenuItem_Click(object sender, EventArgs e)
	diagram.ResizeToFitItems(5);
	diagramView.ZoomToFit();
	// center diagram in view
	RectangleF bounds = diagram.Bounds;
	RectangleF viewport = diagramView.ClientToDoc(diagramView.ClientRectangle);
	PointF diagCenter = GetCenter(bounds);
	diagramView.ScrollTo(
		diagCenter.X - viewport.Width / 2,
		diagCenter.Y - viewport.Height / 2);
	// make sure diagram fills view
	float dx = 0, dy = 0;
	if (viewport.Width > bounds.Width)
		dx = (viewport.Width - bounds.Width) / 2;
	if (viewport.Height > bounds.Height)
		dy = (viewport.Height - bounds.Height) / 2;
	bounds.Inflate(dx, dy);
	diagram.Bounds = bounds;
PointF GetCenter(RectangleF r)
	return new PointF(r.X + r.Width / 2, r.Y + r.Height / 2);
This will zoom preserving the on-screen position of the specified document point; you can use the diagram center instead of mouse position if you need to keep the diagram centered:
private void OnMouseWheel(object sender, MouseEventArgs e)
	PointF docPointAtMousePos = diagramView.ClientToDoc(e.Location);
	int factorToIncrese = e.Delta * SystemInformation.MouseWheelScrollLines / 120;
	diagramView.ZoomFactor += factorToIncrese;
	PointF newPointAtMousePos = diagramView.ClientToDoc(e.Location);
	diagramView.ScrollX -= newPointAtMousePos.X - docPointAtMousePos.X;
	diagramView.ScrollY -= newPointAtMousePos.Y - docPointAtMousePos.Y;
jf2020
I love FlowChart!
Reply #4 - Jul 24th, 2012 at 5:16pm
Stoyan,
Many thanks for the fast answer. I'll try this ASAP and let you know how it goes.
JF
