Normal Topic Can nodes display label in Chinese? and carry hyperlink? (Read 3760 times)
John Zhang
Jul 19th, 2012 at 2:52am
I plan to use Diagramming Components for web application. I have not try this controls and still in phase of experience collection.
anybody can share your experience with me about:
1) Can nodes display label in Chinese?
2) Can nodes carry hyperlink?
Thanks!
John Zhang
Re: Can nodes display label in Chinese? and carry hyperlink?
Reply #1 - Jul 19th, 2012 at 9:18am
Silverlight support Unicode encoding and rendering, so you can display text in any language by setting the Text property of nodes:
var node = diagram.Factory.CreateShapeNode(0, 0, 200, 200);
node.Text = "這是在中國的一些示例文本";
Nodes have a Hyperlink property, which you could navigate to using the Silverlight's browser API from the NodeClicked event. If you need to show a clickable hyperlink as part of a node, you can host a HyperlinkButton class instance inside a ControlNode, or as a part of a larger UserControl hosted inside the ControlNode.
John Zhang
Reply #2 - Jul 20th, 2012 at 3:22am
Stoyan,
Thank you very much.
John
Stoyo wrote on Jul 19th, 2012 at 9:18am:
