Normal Topic New question is coming (Read 1869 times)
CanadaProgrammer
Jul 23rd, 2012 at 11:47pm
I did not come here for a long time.
I want to allow use change the text of DiagramLink. My code is below:
link.Text = "aaaa"; // link is a MyLink type object
there classes are here
class MyLink : MyMyLink
// nothing here
class MyMyLink : DiagramLink
// nothing here
link can be shown on diagram but "aaaa" can not be shown. Give a hand, thanks.
Re: New question is coming
Reply #1 - Jul 24th, 2012 at 6:32am
ShapeNode n1 = diagram.Factory.CreateShapeNode(0, 0, 10, 10);
ShapeNode n2 = diagram.Factory.CreateShapeNode(60, 0, 10, 10);
MyLink link = new MyLink(diagram, n1, n2);
diagram.Links.Add(link);
link.Text = "test";
public class MyMyLink : DiagramLink
	public MyMyLink(Diagram d, DiagramNode n1, DiagramNode n2) : base(d, n1, n2)
public class MyLink : MyMyLink
	public MyLink(Diagram d, DiagramNode n1, DiagramNode n2) : base(d, n1, n2)
shows the text in my test app. The "nothing here" comment cannot be true since you must create at least a constructor to pass arguments to the base DiagramLink constructor. If you are overriding the Draw method, make sure you are also calling base.Draw or otherwise you will have to render the text yourself by calling Graphics.DrawString(). Also make sure TextColor is not set to Color.Empty or Color.Transparent.
CanadaProgrammer
Reply #2 - Jul 24th, 2012 at 4:27pm
Thanks, I found the problem.
One more question, diagram.items.Add(link) and diagram.Links.Add(link) are same?
Reply #3 - Jul 25th, 2012 at 6:44am
Yes, they are equivalent.
