Normal Topic pasting the nodes on the cursor position (Read 3561 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Aug 18th, 2012 at 5:22am
Dear Stoyo,
       i am copying some nodes and want to paste the nodes on the cursor postion. but it is pasting different location. the code i am using is
            Point p = diagramView.PointToClient(Cursor.Position);
            PointF oldcurpos = diagramView.DocToClient(p);
            pasteDX = Convert.ToInt32(oldcurpos.X);
            pasteDY = Convert.ToInt32(oldcurpos.Y);
            diagramView.PasteFromClipboard(pasteDX, pasteDY, true);
kindly help
if you want something then go and grab it
Re: pasting the nodes on the cursor position
Reply #1 - Aug 20th, 2012 at 8:22am
The dx,dy parameters of PasteFromClipboard designate offset from the original position of the pasted items. If you need them pasted at a specific position, you will have to calculate that offset by subtracting the original Selection.Bounds.Location from the  paste location.
madhan1
FROM EVERY ONE ..
Reply #2 - Aug 20th, 2012 at 11:01am
thanks Stoyan,
i have used the following code
            pasteDX = Convert.ToInt32(oldcurpos.X - diagram.Selection.Bounds.Location.X);
            pasteDY = Convert.ToInt32(oldcurpos.Y - diagram.Selection.Bounds.Location.Y);
this code is working in the same file and the nodes are selected
1.  but i have unselected the node and paste. then it is pasting in some other position.
2.  if i paste in another file also it is pasting in some other position.
kindly help
Reply #3 - Aug 21st, 2012 at 6:51am
Do not use the current selection position, but save Selection.Bounds before calling CopyToClipboard and then use the saved position to calculate offset when pasting.
madhan1
FROM EVERY ONE ..
Reply #4 - Aug 21st, 2012 at 9:08am
Thanks alot stoyan
