Normal Topic Problem with Windows 7 (Read 4896 times)
Hunter
Aug 29th, 2012 at 10:50am
Hello.
The problem is following.
When I remove link between 2 nodes inherited from ShapeNode and try to make new link between these nodes I catch the following exception:
29.08.2012 13:46:29. Unhandled exception catched.
System.Security.VerificationException: Operation could destabilize the runtime.
   at A.TJ`1..ctor(Int32 A)
   at A.QJ.X(NJ A, AK B, NJ C, AK D)
   at MindFusion.Diagramming.Wpf.QuickRouter.H(DiagramLink A, QJ B, List`1 C)
   at MindFusion.Diagramming.Wpf.QuickRouter.H(DiagramLink A, QJ B)
   at MindFusion.Diagramming.Wpf.QuickRouter.RouteLink(DiagramLink link)
   at MindFusion.Diagramming.Wpf.DiagramLink.JS(Boolean A, ConnectionPoint B, ConnectionPoint C, Boolean D, DiagramItemCollection E)
   at MindFusion.Diagramming.Wpf.DiagramLink.JS(Boolean A, Boolean B, DiagramItemCollection C)
   at MindFusion.Diagramming.Wpf.DiagramLink.Route()
   at Technologist.TPDEDiagram.OnDiagram_LinkCreated(Object sender, LinkEventArgs e) in D:\Work\TPDE\tpde4\TPDEDiagram_EventHadlers.cs:line 285
   at MindFusion.Diagramming.Wpf.Diagram.OnLinkCreated(LinkEventArgs e)
   at MindFusion.Diagramming.Wpf.Diagram.RaiseCreated(DiagramItem item)
   at MindFusion.Diagramming.Wpf.InteractionState.Complete(Point point, Diagram diagram)
   at MindFusion.Diagramming.Wpf.Behaviors.BehaviorBase.OnMouseUp(Point mousePosition, MouseButton mouseButton)
   at Technologist.LinkBehavior.OnMouseUp(Point mousePosition, MouseButton mouseButton) in D:\Work\TPDE\tpde4\LinkBehavior.cs:line 336
   at MindFusion.Diagramming.Wpf.Diagram.TN(MouseButtonEventArgs A, Point B)
   at MindFusion.Diagramming.Wpf.Diagram.OnPreviewMouseUp(MouseButtonEventArgs e)
   at System.Windows.UIElement.OnPreviewMouseUpThunk(Object sender, MouseButtonEventArgs e)
   at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
On Windows XP this problem is absent.
Re: Problem with Windows 7
Reply #1 - Aug 29th, 2012 at 11:44am
I am running Windows 7 but cannot reproduce this. Could you attach a test project that shows the problem?
Hunter
Reply #2 - Sep 6th, 2012 at 10:23am
I haven't time now to create the test project but I include source codes and compile your dlls under Windows 7. After that I can't reproduce the problem but your and my Diagramming.Wpf, Scripting and Graph libraries have different sizes. My libraries are less than your
Reply #3 - Sep 6th, 2012 at 12:51pm
Our builds are bigger because they are obfuscated. What kind of application are you developing? I can find this exception mentioned only in the context of web applications when there are some trust levels applied.
Hunter
Reply #4 - Sep 6th, 2012 at 1:50pm
This is the application that uses database in internal LAN of the corporation and rertieves some data from the WCF services in this LAN. But how can it influence when I already restored diagram from the string which was recieved from the database?
Reply #5 - Sep 6th, 2012 at 4:30pm
Do you start the .exe file from a shared folder on the network?
Hunter
Reply #6 - Sep 7th, 2012 at 10:21am
No. It is desktop application which started from the local directories and I saw the problem when I started debug version of the application from Visual Studio in my working directory with solution. The directory is under version control (for this purpose we use Git)
Reply #7 - Sep 7th, 2012 at 1:28pm
Are you by chance using the .NET 3 diagramming.dll build in an application that targets .NET 4? This post suggests code generated for one runtime might not be verifiable in another one:
http://stackoverflow.com/questions/6919808/why-does-this-line-cause-a-verificati...
From what I can understand, these verifications are done only when not running under FullTrust level, which usually happens in web applications. Have you by chance applied some security policy to your application to make it work under a different level?
Reply #8 - Sep 18th, 2012 at 4:59pm
We have upgraded to a newer version of the obfuscation software we are using, could you check if the build from the PM page works any better under your security settings?
