Normal Topic Limitation bounds of the ShapeNode (Read 1872 times)
Hunter
Sep 11th, 2012 at 8:48am
Hello. How can I limit size of the ShapeNode? I need to set height of the node lager then 10 for example while user resizes it by mouse
Re: Limitation bounds of the ShapeNode
Reply #1 - Sep 11th, 2012 at 10:19am
Set node.Constraints.MinHeight = 10.
Hunter
Reply #2 - Sep 11th, 2012 at 11:56am
Thanks!
