Normal Topic How to change the mouse cursor to "Hand" if the mouse is over link's end? (Read 2124 times)
Homam
Sep 29th, 2012 at 12:46pm
How to change the mouse cursor to "Hand" if the mouse is over link's end or start?
Re: How to change the mouse cursor to "Hand" if the mouse is over link's end?
Reply #1 - Sep 30th, 2012 at 6:15am
You could set DiagramView.MoveCursor to Cursors.Hand, but it will also appear for other control points. If you need to show it only for the first and last points, set the OverrideCursor property when you detect the mouse if over the respective handles:
private void diagramView_MouseMove(object sender, MouseEventArgs e)
	PointF mousePos = diagramView.ClientToDoc(e.Location);
	DiagramLink link = diagram.GetLinkAt(mousePos, 3);
	if (link != null && link.Selected && (
		Utilities.Distance(link.StartPoint, mousePos) <= diagram.AdjustmentHandlesSize ||
		Utilities.Distance(link.EndPoint, mousePos) <= diagram.AdjustmentHandlesSize))
		diagramView.OverrideCursor = Cursors.Hand;
	else
		diagramView.OverrideCursor = null;
Homam
Reply #2 - Sep 30th, 2012 at 1:36pm
It worked well. Thank you.
